Jennifer B
Hi, I am wondering if there is a booster type pump that is designed to purposely turn itself off when it starts to pump air. I understand that some pumps will shut themselves off if they are stressed by pulling air, but I am talking about a pump that is happily designed for that function.
My situation is that I wish to pump water up to a holding tank from two lower tanks that collect rainwater from my roof, and my installer is concerned that when I go to do that pumping (which will probably only need to be done 3-4 times a year) that something could distract me and the pump could finish pumping, suck air and burn out.
There is only electrical power at the top of the system, where the holding tank is, so pushing the water up is not an option.
I can and will put in a mechanical check valve at the bottom of the slope (where the two rain tanks are) so any water in the line won't drain back and cause me to have to prime the system again.
The lift is about 30 feet from bottom of lower tanks to fill line of top holding tank.
I appreciate any suggestions!
