Pump stops pumping
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by George Racine, Feb 9, 2005.
  1. George Racine
    George Racine New Member
    Feb 9, 2005
    The well pump stopped pumping until I bled a small amount of air off of the bladder tank. The pump then started pumping and was fine for about 24 hours. Today the same conditon exists. The pump runs but does not pump.I am about to get public water in a few weeks. I am trying not to spend too much on the well system if I don't have to.
Similar Threads: Pump stops
Pumps and Tanks Well Forum & Blog. Water is life. Water pump stopped. Short cycles then stops. Jan 19, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Pump runs then all of sudden stops Mar 29, 2016
Pumps and Tanks Well Forum & Blog. Water is life. pump stops periodically May 27, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Pump cycles on and off several times, stops at 20 psi Apr 27, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Supply line froze, after thawing water runs back into well when pump stops... Jan 4, 2014
