Pump starter relay
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by fendall, Aug 21, 2013.
  1. fendall
    fendall New Member
    Aug 21, 2013
    Atlanta
    Just replaced 1.5hp flotec pump with 2.0 hp, but now can't get relay to start pump. It clicks, and my meter shows I'm getting 120 v at the pump, but pump won't come on. Checked my 20 year old starter relay and noticed it was only rated for 1 hp at 120v ( although it's worked great with the 1.5 hp pump). I'm guessing I need a new relay rated for 2 hp at 120v, but don't want to spend the money if this isn't the most probable problem. Any suggestions? Pump comes on when I plug extension cord direct to it. Thanks
  2. masterpumpman
    masterpumpman New Member
    Mar 26, 2007
    Consult and Teach Well Drilling Internationally
    Virginia Beach, VA
    Not enough information to make an accurate diagnosis but I suspect that your 1.5 and 2 hp pump needs 220 volts to work best. Is this a jet or submersible pump?
  4. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    2 HP pump should be wired for 240, not 120.
  5. fendall
    fendall New Member
    Aug 21, 2013
    Atlanta
    Thanks guys, but pump is rated for 120v
  6. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    What model is it ?
    When you say Pump starter relay, are you talking about the pressure switch ?
  7. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    If you have 120 going to the pump and the pump won't run then you either have no connection at the pump or the pump is bad out of the box. Either way, the pump need to come out again
  8. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    If it is a Jet pump, that is what I was thinking it was, Someone may have forgot to set the voltage. But it was said that it works on a extension cord. ??
    A 2 HP pump should be on 240, That is what I would use.
    Not that 120 wont work with bigger wire, 240 will work more better. Some 2 HP pumps will not even have a 120V setting. (The Good ones don't, or they are not really 2 HP, People like big numbers.)
    I also would not use a 1 HP control for a 2 HP pump, That is asking for trouble.
    More details would be nice.
    PS. I like your tag line, actually rocket science requires many licenses, Thanks to ISO and OSHA.
Similar Threads: Pump starter
Pumps and Tanks Well Forum & Blog. Water is life. Franklin Motor Starter or Franklin Pump Motor? Sep 28, 2013
Pumps and Tanks Well Forum & Blog. Water is life. Pump starter turns off after 9 seconds Aug 19, 2009
Pumps and Tanks Well Forum & Blog. Water is life. Helplease....Sprinkler pump and pressure tank Yesterday at 7:51 PM
Pumps and Tanks Well Forum & Blog. Water is life. Well pump varies, Please help I'm clueless Wednesday at 9:38 PM
Pumps and Tanks Well Forum & Blog. Water is life. Shallow well jet pump failing to reach cutoff Wednesday at 7:59 AM
