Pump Start Relay / timer
Discussion in 'Irrigation / Sprinkler Forum' started by dmathieu, Jun 26, 2008.
  1. dmathieu
    dmathieu New Member
    Jun 18, 2008
    I.T.
    Litchfield NH
    I just put in drive point well for a future sprinkler system but I am not putting the sprinklers in this year. For now I would like to have a regular hose and sprinkler on a timer.
    How can I get my pump to turn on automatically? Can I use a pump start relay and a sprinklers controller for now, or will that only work with valves?
    Should I get a pressure tank?
    Thanks for any advice you can provide.
    Dave
  2. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    With a point you are probably using a shallow well jet pump.
    You can use a relay to start the pump. However, the easiest way is to use a pressure tank with a pressure switch. The pump will keep the tank pressurized and will start the pump when you start irrigating with hose or sprinkler system.
    I suggest that you take care to match the pump and watering system so the pump runs continupusly when you are watering. Set the switch shutoff pressure to about 5 to 10 psi less than the shutoff pressure of the pump (experiment) and use a sprinkler on the end of the hose so it is not being shut off frequently.
Similar Threads: Pump Start
Irrigation / Sprinkler Forum Home irrigation pump start relay intermittent shut off issues Jul 25, 2013
Irrigation / Sprinkler Forum pump start relay bad? (hunter sprinklers) Oct 4, 2011
Irrigation / Sprinkler Forum Pump holds prime but pressure drops to zero when starting Jun 22, 2011
Irrigation / Sprinkler Forum convert from holding tank to pump start relay Apr 17, 2011
Irrigation / Sprinkler Forum Pump start relay switch - how to install Aug 16, 2009
