Pump start relay switch - how to install
Discussion in 'Irrigation / Sprinkler Forum' started by garberfc, Aug 16, 2009.
  1. garberfc
    garberfc New Member
    Apr 23, 2009
  2. hj
    relay
    According to the sheet, an "E" relay needs 480 v to the coil. You need a "G" version
  4. garberfc
    garberfc New Member
    Apr 23, 2009
    I've been trying to get the system using the wrong switch! I found the original and it's a model SP07. Will you please look at the attached file and let me know...
    What does it mean "to the coil". Is this the amount of voltage required to close the contacts??
    Thanks in advance,
    F
  5. hj
    relay
    IT should be an SP07-G to use a 24 volt input to the coil. I don't see the "to the coil" listing, but that should be the voltage to operate the relay.
Similar Threads: Pump start
Irrigation / Sprinkler Forum Home irrigation pump start relay intermittent shut off issues Jul 25, 2013
Irrigation / Sprinkler Forum pump start relay bad? (hunter sprinklers) Oct 4, 2011
Irrigation / Sprinkler Forum Pump holds prime but pressure drops to zero when starting Jun 22, 2011
Irrigation / Sprinkler Forum convert from holding tank to pump start relay Apr 17, 2011
Irrigation / Sprinkler Forum Pump Start Relay (I think) Aug 11, 2009
