Pump Start Relay (I think)
Discussion in 'Irrigation / Sprinkler Forum' started by he8833, Aug 11, 2009.
  1. he8833
    he8833 New Member
    Aug 11, 2009
    Minnesota
    Ok guys I need some help newbie to all of this
    here is the setup trying to help my pop out
    3/4 horse lake pump plugged into outlet 10 feet from shoreline 115 line run from outside outlet to a 30 amp circuit which is on the main electrical panel for house
    Coming directly off the pump has a 4 valve spicket like this http://www.berryhilldrip.com/images/62032FauPic.jpg in which 3/4 inch polyethylene tubing is connected. He primarily only uses 2 of the four lines. First line has the "stake in ground sprinklers" coming off the tubing for watering the lawn covers the lawn great...
    2nd line is for watering a garden bed
    The most efficent way @ the moment is he walks down into the basement to turn on the circuit which turns on the pump (not very pratical)
    Question for this post so I can better understand the fundemntals
    Is their such thing as pump start relay with a timer built in timer? This way its simply turns on the pump and only 1 valve is open (single zone) which waters the lawn based on a schedule. In my limitied reading it sounds like most pump start relays are connected to a irrigation controller. However its sounds like a controller is neccessary when you have multiple zones (valves)? If we wanted to keep this really basic as to simply control 1 zone....Does such a pump start relay exist.
    Any other suggestions are welcome
    thanks in advance
  2. onedrop
    onedrop New Member
    Aug 7, 2009
    I haven't heard of a pump start relay that acts as a single station irrigation timer. You can get a single station timer though. I would just get a regular 4 station controller along with a pump star relay.
Similar Threads: Pump Start
Irrigation / Sprinkler Forum Home irrigation pump start relay intermittent shut off issues Jul 25, 2013
Irrigation / Sprinkler Forum pump start relay bad? (hunter sprinklers) Oct 4, 2011
Irrigation / Sprinkler Forum Pump holds prime but pressure drops to zero when starting Jun 22, 2011
Irrigation / Sprinkler Forum convert from holding tank to pump start relay Apr 17, 2011
Irrigation / Sprinkler Forum Pump start relay switch - how to install Aug 16, 2009
