Pump sizing
Discussion in 'Irrigation / Sprinkler Forum' started by dougle, Mar 16, 2008.
  1. dougle
    dougle New Member
    Sep 9, 2006
    British Columbia
    What would happen if i connected a jet shallow pump 3/4hp to a system (lateral)that required only 5 gpm. Flow out of the pump with no pressure (no resistance) is 9gpm. I have no pressure settings on this pump, turn it on and let it pump. Will the pump burn out as the resistance (5gpm) is not enough for the pump? i know that the pressure will increase as it tries to put 9 gpm out. have i got this right? just trying to size a system.
  2. Bob NH
    Bob NH In the Trades
    Oct 20, 2005
    New Hampshire
    The pressure will increase and the pump should work fine.
    Shallow well jet pumps are tolerant of throttling and will operate at a point that is stable for the conditions of lift and discharge pressure. The final pressure will depend on suction lift and flow rate and will probably be somewhere in the range of 50 to 70 psi.
  4. dougle
    dougle New Member
    Sep 9, 2006
    British Columbia
    Thanks Bob, I assume then that increasing the flow rate (ie adding another head) would reduce the pressure? (ie to 40-45psi) thanks
  5. Bob NH
    Oct 20, 2005
    New Hampshire
    Yes. You can test the pump, or look at the curve for the particular model.
    9 GPM is quite low flow for a 3/4 HP shallow well jet pump.
    Here is data for a Goulds 3/4 HP J7 convertible or J7S shallow well jet pump. The unbolded entries are GPM at the Pressure/Lift conditions.
    . . . . Pressure - PSI
    Lift, 30.0, 40.0, 50.0, 60.0, MaxP
    5 ft, 21.3, 18.3, 12.5, 6.6, Max70
    10 ft, 18.8, 17.3, 11.3, 5.0, Max 68
    15 ft, 16.4, 15.5, 9.6, 3.7, Max 66
    20 ft, 13.6, 13.2, 8.3, 2.0, Max 63
    25 ft, 10.0, 9.9, 6.4, 1.0*, Max59
    *The 1.0 GPM entry at 60 psi doesn't make sense for a pumping condition that makes 59 psi max but that is what was in the table.
  6. dougle
    dougle New Member
    Sep 9, 2006
    British Columbia
    Thanks so much Bob.
Similar Threads: Pump sizing
Irrigation / Sprinkler Forum How to calculate pressure to choose water pump Dec 26, 2016
Irrigation / Sprinkler Forum Shallow well pump issues Sep 24, 2016
Irrigation / Sprinkler Forum Simple garden hose sprinkler on Well pump issue Jun 25, 2016
Irrigation / Sprinkler Forum Well pump just bubbling, no pressure May 22, 2016
Irrigation / Sprinkler Forum Timer for irrigation pump? May 13, 2016
