pump saver submersible pump switch
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by latillasteve, Jun 15, 2012.
  1. latillasteve
    latillasteve New Member
    Jun 14, 2012
    Arizona
    My Pump Saver mod.# 231, 230 volt is over 20 yrs. old and just started switching off when trying to reestablish pressure. Will now only build 2-3 lbs. then switches off, so I have to keep throwing the fused breaker box switch off/on in order to build pressure. Do I need a new switch?
    Steve
  2. ballvalve
    Dec 28, 2009
    northfork, california
    You got your moneys worth. Invest in a new control box AND franklin pumpsaver. Then you will likely discover that your pump is shot, but they are compatible with a new pump with a franklin motor. Most pumps go 7 to 15 years, and first make sure your pressure tank is working. If its 20 years old its shot too. Go over to the pump section stivkies for more info.
Similar Threads: pump saver
Plumbing Forum, Professional & DIY Advice pump saver submersible pump switch Jun 15, 2012
Plumbing Forum, Professional & DIY Advice Basement under counter sump pump Feb 7, 2017
Plumbing Forum, Professional & DIY Advice Home run w/PEX how about a heat circulating pump? Feb 5, 2017
Plumbing Forum, Professional & DIY Advice Sump Pump Vent Jan 31, 2017
Plumbing Forum, Professional & DIY Advice Turning on well pump at breaker box Jan 30, 2017
