pump saver submersible pump switch
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by latillasteve, Jun 15, 2012.
when pump saver submersible pump switch won't build 2-3lbs. before swithing off.
  1. new switch ?
    0 vote(s)
    0.0%
  2. replace entire pump saver switch ?
    0 vote(s)
    0.0%
  1. latillasteve
    latillasteve New Member
    Jun 14, 2012
    Arizona
    My Pump Saver mod.# 231, 230 volt is over 20 yrs. old and just started switching off when trying to reestablish pressure. Will now only build 2-3 lbs. then switches off, so I have to keep throwing the fused breaker box switch off/on in order to build pressure. Do I need a new switch?
    Steve
  2. ballvalve
    Dec 28, 2009
    northfork, california
    Neither. TEST your pump amp draw and wire insulation. TEST your pressure tank. TEST your control box if you have a 3 wire pump. Whatever parts of this system is 20 years old ALL need replacement.
  4. DIYPlumber90
    DIYPlumber90 New Member
    Mar 31, 2012
    CA
    That might actually be a great recommendation...
Similar Threads: pump saver
Plumbing Forum, Professional & DIY Advice pump saver submersible pump switch Jun 15, 2012
Plumbing Forum, Professional & DIY Advice Replace Grundfos UP 10 Pump with UP 10-16 PM Friday at 10:06 PM
Plumbing Forum, Professional & DIY Advice Well pumps Mar 19, 2017
Plumbing Forum, Professional & DIY Advice Septic system-- to what degree do I try to avoid a pump in the system? Mar 17, 2017
Plumbing Forum, Professional & DIY Advice Need help with Pump Pressure switch shutoff Mar 15, 2017
