Pump rebuild kit needed - Water Ace
Discussion in 'Pumps and Tanks Well Forum & Blog' started by yar02169, Apr 2, 2008.
  1. yar02169
    yar02169 Member
    May 7, 2007
    Quincy, MA
    I'm looking to rebuild a Water Ace R10L pump. I contacted the manufacturer and they recommended that I save shipping charges and go to my local Lowe's as they sell the Water Ace line.
    I've visited three stores now, and they do sell the pumps, but none sell rebuild kits (must be that I'm in the Northeast). The Lowe's web site isn't to clear on what the kits include, and they don't use the same part numbers as the manufacturer.
    I'm looking for two kits, one is the impeller kit, and the other is the seal kit (RPK-10LS and RPK-LSS respectively).
    Does anyone know the Lowe's P/N's, or can someone here provide me with a decent price for these kits?
    Thanks,
    Ray
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    They are the same as the Myers. The dirty trick they play is using a different shaft thread size than anyone else. If you give me the part number off the impeller, I can get you a replacement. If you nuked the impeller, chances you nuked the diffuser as well. The seal is a PS 200 for a generic part number. It's a very popular seal and can be purchased anywhere as well as from me.
    The Water Ace model numbers don't cross with anything I'm familiar with, that's why I need a part number.
    bob...
  4. yar02169
    yar02169 Member
    May 7, 2007
    Quincy, MA
    Bob-
    Well, I didn't nuke the impeller, so I have some luck on my side. The part number is 20600B3. As mentioned in my initial message, I'm interested in getting the entire re-build kit. If you can let me know the cost. and how to order from you, it would be apprecaited.
    Ray
  5. speedbump
    Jul 15, 2005
    Riverview, Fl.
    What do you mean by a rebuild kit? There is the Impeller (which you don't need), the Diffuser which covers the impeller. The O-ring can be reused. The seal is the only thing I would replace and that's only if you removed it or it was already leaking.
    bob...
  6. yar02169
    yar02169 Member
    May 7, 2007
    Quincy, MA
    Well, the pump is known to be at least 18 years old before it started leaking. he diffuser is cracked. Both the diffuser and impeller have some good wear grooves on their faces, and the o-ring has done its job for all these years.
    Before I install it for the season, and since it's currently dis-assembled, I would like to change all of the wearable/changable parts.
    On page 7 of the Water Ace repair manual (http://www.waterace.com/pdf/R7L R10L R15L R20L and R25L Lawn Sprinkler Pumps Manual.pdf) they list one kit for the diffuser & impeller, and another kit that includes; seal shaft, impeller seal, slinger, gasket 8 3/4 OD, & gasket 2 1/8 OD.
    I figured if I bought both kits, I'd be covered.
  7. speedbump
    Jul 15, 2005
    Riverview, Fl.
    I wouldn't waste my money on an 18 year old Water Ace. I'm amazed it's still able to run at all since they use the cheapest GE motor they can find on those pumps.
    Buy a new one and quit messing with something that is doomed to fail very soon anyway.
    bob...
  8. yar02169
    yar02169 Member
    May 7, 2007
    Quincy, MA
    OK, thanks for the advice.
    Ray
Similar Threads: Pump rebuild
Pumps and Tanks Well Forum & Blog 1 - 1/2 hp irrigation pump rebuild? Aug 8, 2013
Pumps and Tanks Well Forum & Blog Fairbanks Morse jet pump...is it smart to rebuild it? Jun 21, 2012
Pumps and Tanks Well Forum & Blog Can I rebuilding a deep well pump? Jun 6, 2012
Pumps and Tanks Well Forum & Blog deep well jet pump, no pressure after rebuild Jul 3, 2011
Pumps and Tanks Well Forum & Blog About to rebuild booster pump, could someone please review my procedure? Sep 30, 2010
