Pump Problem?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by caribu, Oct 18, 2011.
  1. caribu
    caribu New Member
    Oct 18, 2011
    Michigan
    About a week ago I went to turn my shower on and noticed that when I turned my water on it ran at a very slow trickle then turn on with normal pressure after about 20 to 30 seconds. I have not noticed any problems for about a week. This morning my daughter called me with the same problem but this time the water was trickling out very slow for a longer period of time then suddenly turned back on with normal pressure. We have a well, not sure how deep. The pressure tank was replaced in December of last year. The pressure gauge appears to be holding at normal ranges. It is very inconsistent so I'm having a hard time trying to figure out what's happening. Any ideas?
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    My guess is that you are not looking at the gauge at the moment that the water is a mere trickle. The gauge could well be lying and the pressure switch may be failing.
    Most likely, the tank is empty at the time and the jet pump (I'm guessing) is just starting and starving for pressure. Make sure the tank precharge is not too high for the switch kick-in setting.
  4. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    If this is a jet pump, I would think you are losing prime.
  5. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    I think it's losing its head, not its prime. A jet pump uses pressure to make more pressure. At the same time it uses volume to make more volume. If you cut the precharge too fine, the pressure dives just as the pump is coming on and hesitates. How would the precharge vary over time?
    A pressure switch setting can drift with age or from mineral buildup under the diaphragm. A bladder can fail over time and slowly "jack up" the precharge or silt/can displace the water between the bladder and the tank.
    A common mistake that people make when setting the precharge is to assume their air pressure (usually read with a tire gauge) reads the same as their water pressure gauge. Seldom do they read the same and so they need to be calibrated.
Similar Threads: Pump Problem
Pumps and Tanks Well Forum & Blog. Water is life. Submersible pump problems Jan 11, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Pressure pump problem Dec 21, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Air Lift Well Pump Problems Nov 23, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Problems pumping lake water to cottage Aug 23, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Jet pump problem May 10, 2016
