John and jill
hi,
I installed a flotec 6s 10 months ago, using a Yaoda Skd -3 control valve. After 9 months use, the pump stopped, I checked the valve and pump, found the pump had either a broken shaft or impeller, actually the motor had burnt out. Received a free replacement flotec 6s plus, fitted and fired it up, worked superb for 4 weeks, then no water on demand, pulled up pump, Same problem pump motor burnt out. Can anyone help me with what the problem might be, I suspect electrics, but have checked the control valve wiring, it seems ok, I cannot get an English version of. Wireing diagram, can anyone help with this.
Best regards.
John.
Best regards.
John.
