Pump Losing Prime Quickly
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by xenon, Nov 27, 2012.
  1. xenon
    xenon New Member
    Nov 27, 2012
    Florida
    I have a 120' well used for irrigation here in south Florida. Pipe is galvanized 2 & 1/2". Pump is a 1 & 1/2 hp Goulds centrifugal on a concrete slab next to the well pipe.
    After the pump was left unused for 5 months during the rainy season, it is losing prime within minutes after shut off.
    First I replaced the horizontal mounted check valve between well and pump. No change.
    Then I brought pump in and had it rebuilt, as it was probably 12 years old anyway. No change.
    I can get it to prime by attaching a hose to the bib on top of the pump, and running water in while the pump is operating. After 10 or 15 minutes the pump will prime. Once primed the pressure is excellent.
    There is no lack of water as the water table is now about 4' below ground surface.
    Any diagnosis?
    Thanks.
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    A good footvalve is the best way to keep from losing prime. You probably have one that is leaking back.
  4. xenon
    xenon New Member
    Nov 27, 2012
    Florida
    Thanks for the response. I took the plug off the top of the well pipe. Turns out there is no drop pipe; just the well casing. Water level is right at six feet down. Took a hose and ran water into the pipe to see if I could fill it. Pulled the hose after about five minutes and the level did not rise much but there was a lot of bubbling. Large bubbles.
    Dug the pipe down to about five feet. Pipe was clean to about four feet down and then had what looked like surface rust. Water started to show at base of the hole. Could be the ground water or could be from a hole in the pipe.
    What to do now?
  5. justwater
    justwater Well Drilling/Service
    May 13, 2010
    FL/GA
    toss the above ground check valve and install 30' of 1-1/4" pvc drop pipe into the well with a foot valve on the bottom, then plumb that into the pump.
    ** fyi, i say 1-1/4" to get max volume but be careful because some fittings are tight inside a 2" ID well. i sometimes turn them down a little on a grinder before installing... you'll need to pull it all out again one day.
  6. xenon
    xenon New Member
    Nov 27, 2012
    Florida
    Thanks, that is a big help and explains about the 1 & 1/4".
    What fittings would I need to plumb the drop pipe to the pump?
  7. justwater
    May 13, 2010
    FL/GA
    they make a double tap fitting that screws into a 2" coupling and is tapped 1-1/4" on both sides.
    OR... use a simple 2" pvc threaded cap, drill a hole with a paddle bit that is just large enough that the drop pipe barely slips through.. slip pipe through and glue elbow/coupling onto pipe and let the drop pipe rest on the fitting. this is easier/cheaper and works quite well. you can seal it up with some silicone or something but if you make it a tight fit and being as its irrigation anyway.. its not necessary.
  8. xenon
    xenon New Member
    Nov 27, 2012
    Florida
    Excellent solution and right price, too.
    Thanks for your help. Much appreciated.
Similar Threads: Pump Losing
Pumps and Tanks Well Forum & Blog. Water is life. Sand Point Well; pump losing prime Sep 19, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Jet Pump losing prime with new foot valve after sitting 4 -5 hrs Aug 12, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Pump losing prime? Jul 1, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Tankless Submersible Well Pump losing pressure Jul 7, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Pump losing pressure fast. Mar 18, 2011
