pump keeps blowing fuses
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Molly, Dec 12, 2007.
  1. Molly
    Molly New Member
    Nov 1, 2005
    Every time my pump (submersible) comes on, it is blowing fuses. What could be the cause of this? It is the only thing wired to the fuse box, and it has been ok for years until now.
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    If it has been OK for years, don't you think it may be that it is wearing out? If you are not able to troubleshoot it with a little help from someone here, you might have to call a pump man or a well driller.
    bob...
  4. Molly
    Molly New Member
    Nov 1, 2005
    You think the pump is bad? I was thinking it was something electrical.
  5. speedbump
    Jul 15, 2005
    Riverview, Fl.
    In order for us to be helpful, your going to have to explain what kind of equipment you have. Pump, tank, well etc. Tell us what other things you have noticed beside just blowing fuses.
    bob...
  6. Rancher
    Rancher Guest
    The pump is electrical, it could be the motor on the pump has siezed, or the wire down the shaft has rubbed and shorted out, if you have an ohm meter and know how to use it we can help you trouble shoot.
    1. Do you have a pump control box, which is not the pressure turn on switch.
    2. You have fuses? Or circuit breakers.
    3. Do you know how far down the pump is.
    4. Do you know how old the pump is.
    Rancher
Similar Threads: pump keeps
Pumps and Tanks Well Forum & Blog. Water is life. Pump keeps loosing prime, lots of air Oct 3, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Pressure on pump keeps going up, up, and up. Bad pressure switch? Jan 19, 2015
Pumps and Tanks Well Forum & Blog. Water is life. VERY low water pressure but pump keeps running Oct 9, 2013
Pumps and Tanks Well Forum & Blog. Water is life. Help!!! Pump keeps running and won't stop!!! May 29, 2012
Pumps and Tanks Well Forum & Blog. Water is life. Replaced 3 foot valves and pump keeps running Sep 13, 2011
