I just moved into a home with well-water. I've noticed that the pump seems to be kicking on and off immediately when water is discharged. I'm no expert, but I'm fairly certain it shouldn't be doing this. I already see that I need to replace the pressure gauge, so don't know what the actual pressures are when it's kicking on and off. I'm not sure if the pressure switch is functioning correctly either. The pressure in the tank is about 25 psi as measured at the schraeder valve on the tank top.
Here's the video of what happens when I turn on the water:
I'd really appreciate anyone's input. Thanks!
