Pump/Hose Thread Question
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by mpr2000, May 6, 2013.
  1. mpr2000
    mpr2000 New Member
    May 6, 2013
    Upstate NY
    So this is more specifically a pool/filter and hose question, but I think this is the right forum to ask...
    On my pool filter, I have an 1-1/2" port for the discharge hose (backwash). The thread on this is standard (NPT?) and accepts the sched 40 PCV threaded fittings you'd find at the usual supply houses.
    I grew tired of replacing the cheap plastic hose generally used for pool discharge and purchased a water discharge hose meant for a trash pump. This is 1-1/2" PVC reinforced hose and has "Pin Couplings", male at one end and female at the other. The thread on these couplings (i think) is NH-NST?
    So - the question is - can anyone help me validate the thread type of each? I think what I need to connect the hose to my filter is an adapter like: Female Thread 1-1/2" NPT to Male Thread 1-1/2" NH(NST). The NPT female would use a short coupler in to the filter, and the NH Male would allow me to connect the Female (pin coupling) end of my water disharge hose.
    Any input/feedback is appreciated!
    Mark
  2. VAWellDriller
    VAWellDriller Member
    Sep 8, 2012
    Mud rotary well driller, pump installer
    Richmond, VA
    If it's straight thread with a rubber gasket in the female hose end, you can mate that to NPT, no adapter needed....just buy a 1.5" NPT steel nipple and screw it into the filter, screw the hose on that.
  4. mpr2000
    mpr2000 New Member
    May 6, 2013
    Upstate NY
    Thanks for the quick reply. The female end of the hose does have a gasket, so I'll try a steel nipple. What may have thrown me, was that I tried a PVC nipple I had laying around, and it would turn about 1-1/2 turns on the female hose fitting and bind up.
  5. VAWellDriller
    Sep 8, 2012
    Richmond, VA
    It won't thread very far on NPT...the threads don't make the seal...the gasket does.
Similar Threads: Pump/Hose Thread
Pumps and Tanks Well Forum & Blog. Water is life. Thread sealant Apr 8, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Where can I find a 3" Swing check with BSP threads? Mar 3, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Where to buy threaded/flush pvc for well casing? Jan 2, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Threads on pitless adapter appear damaged Jul 18, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Is PVC pipe sometimes screwed into coupling without being threaded first? Jun 9, 2014
