Pump Ground Wire
Discussion in 'Pumps and Tanks Well Forum & Blog' started by bobabuoy, Mar 1, 2006.
  1. bobabuoy
    bobabuoy New Member
    Jan 30, 2006
    I have a three wire sumbersible pump. I can see the red, yellow and black wires coming up from the well, but I don't see any green ground wire. Is this safe? Should there be a ground wire coming up to the motor control box?
  2. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    Yes, it's safe. The new code that came about sometime in the 80's added the green wire to submersible motors. Yours must be quite old by now and when it gets changed, the new one will require the four wires instead of three.
    bob...
  4. rshackleford
    rshackleford New Member
    Oct 18, 2005
    Eastern Montana (The Bakken)
    spedbump is right.
    it gets a bit confusing. a two wire pump really has three wire and a three wire really has four wires.
Similar Threads: Pump Ground
Pumps and Tanks Well Forum & Blog Above Ground Well Pump Cracked in the Cold Dec 12, 2013
Pumps and Tanks Well Forum & Blog Grounding a submersible pump Jun 21, 2013
Pumps and Tanks Well Forum & Blog Above ground pool pump question. Garden hose?? May 31, 2013
Pumps and Tanks Well Forum & Blog need reccomendations on submersible pump for underground storage tank Jan 21, 2013
Pumps and Tanks Well Forum & Blog Exterior Sump Pump Basin Popped Out Of Ground! May 20, 2012
