Pump fails to come on occasionally
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by country kid, Aug 26, 2012.
  1. country kid
    country kid New Member
    Jul 20, 2010
    Eastern Oregon
    Control box humms and the pressure gauge is registering 0. Tap the control box and it starts pumping or if the circuit breaker is switched off and on it will kick on. Not a user of multi meter. Can run for a couple of days and no problem or run a couple of cycles and happen again. Pump is 240' deep.
    Thanks for any clues.
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Sounds like a bad control box. Replace it.
  4. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    Probably have a bad starting capacitor and starting relay in the control box. Could also have burned points in the pressure switch. Your motor could also be damaged and tripping the overload. Burned motor and pressure switch along with bad start cap and start relay are caused by “starting too much”, also called “cycling”. Just like we know smoking will give you lung cancer, we also know cycling is the number one killer of pump systems. And although there is no cure for cancer yet, there is a cure for cycling.
  5. country kid
    Jul 20, 2010
    Eastern Oregon
    Electrician out this afternoon be back in a couple of days, has to order a part for control box. Says Burned contacts which is not to unheard of. Thank you all for the replies. We shall see if that is the end of the saga!!!
  6. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    Your average control box new is around $50 - $60. Less than what it cost to pay someone to rebuild the old one, plus you can have the water back on the same day.
  7. country kid
    Jul 20, 2010
    Eastern Oregon
    Franklin 5hp on E-Bay for $276 is the least expensive I have located!
  8. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    Sorry, I was quoting for a 1HP. Not many 5HP pumps around here.
  9. country kid
    Jul 20, 2010
    Eastern Oregon
    no problem. Did not mean to be harsh! One quote was $550 and that made my hair stand up. Thanks for all the replies.
Similar Threads: Pump fails
Pumps and Tanks Well Forum & Blog. Water is life. Deep well pump repeatedly fails to kick in May 16, 2011
Pumps and Tanks Well Forum & Blog. Water is life. Water Not Flowing Into House, Is It The Pump? Friday at 6:21 PM
Pumps and Tanks Well Forum & Blog. Water is life. Flat or twisted cable for deep well pump Thursday at 8:25 AM
Pumps and Tanks Well Forum & Blog. Water is life. Well pump replacement and bad advice Tuesday at 4:05 PM
Pumps and Tanks Well Forum & Blog. Water is life. Well pump issues Tuesday at 7:09 AM
