Well basically we needed to replace the pump in our well. The pump that was previously in our well was 3/4 horsepower and we looked for the same horsepower but all the ranch store had was 1/2 horsepower. This is the only place in the area to get a submersible pump for water wells,that we know of,so we didn't have much of a choice. We install the pump and turn it on, now the waterpressure goes gets high enough but the pressure only last about 5 minutes and it goes down(20psi) when running the water. Then the pump does short cycles to bring the pressure back up. But when we don't run the water it maintains good pressure (60psi) according to the pressure tank.
We haven't replaced the water pressure tank and it looks pretty bad off so that might need to be replaced ,also we haven't put air into the waterpressure tank since the system was turned off 1 day ago.
So the question is, is the difference in horsepower causing the low water pressure or could it be that we need to charge the waterpressure tank with air or replace the water pressure tank altogether?
Anyway sorry for the long post, I just wanted to get you guys all the relevent info I could ,we are new to this whole well thing so we are learning as we go.
