1. motovet123
    motovet123 New Member
    Feb 16, 2011
    virginia
    4 years a go i replaced my 1/2 hp shallow well ( 65 feet ) pump with a 3/4 hp ( it was only thing available on a Sunday evening.. I also replaced my expansion tank at the same time. Recently my bladder ruptured so i replaced the tank AND switch. New tank is a 44 gallon switch is a 30/60. My empty tank pressure was set to -2 llb's below the total pressure. Approx 37 psi according to the instructions. With that being said,,, my pump cycles with only a toilet flush. Could i have reversed the wires on the switch?
    Help!
  2. Gary Slusser
    Retired
    The air pressure with no water in the tank should be 1-2 psi less than the turn the pump on switch setting; 29-28 psi if you run 30/60.
  4. motovet123
    Feb 16, 2011
    virginia
    Whoops, i made a typo... I meant to say 27 psi with the tank empty.
  5. justwater
    justwater Well Drilling/Service
    May 13, 2010
    FL/GA
    well, unless your toilet uses 15 gallons when it flushes... you got something else going on.
  6. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Is there a check valve on the inlet line to the tank?
  7. motovet123
    Feb 16, 2011
    virginia
    I don't think there is a check valve..... I'll check tomorrow when i get home.
Similar Threads: Pump cycling
Pumps and Tanks Well Forum & Blog. Water is life. Pump is short cycling, not sure wha to do Jan 12, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Grundfos MQ3-35 booster pump short cycling Nov 30, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Pump is short-cycling. Tank bladder issue? Aug 30, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Well Pump Short Cycling Issue Jul 6, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Short cycling of well pump when no water is running Aug 2, 2015
