Pump cycling with low differential
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by kp, Jun 27, 2005.
  1. kp
    kp New Member
    Jun 26, 2005
    Our pump is cycling on and off. I checked the pressure gauge and it seems to turn on around 62 and off at 66. Other posts and web searches suggest that these values should be 40 and 60. The pressure switch appears to be in two parts. One is the sensor itself connected in the pipe. A wire leads from the sensor to the electric box with relays attached to the pump.
    There is an adjustment screw the sensor part. I presume that sets the limit. But I do not see an adjustment screw for a differential.
    The pump is 25 years old. It is an above ground pump. The pressure tank was replaced in 1999 with a Champion tank.
    Is there an adjustment for the differential or did older units not have one? I presume the problem is with the pressure switch or could it be something else?
    Thanks for your help.
    Ken
  2. Gary Slusser
    Retired
    Since the switch is so far out of adjustment, replace it with a 30/50 due to the age and type of pump you have. Clean any debris out of the port it attaches to or any tubing or nipple it is mounted on, along with any tubing and fitting any tubing to the switch is screwed into and the holes the fitting is screwed into.
    Adjust the air pressure in the tank to 29-28 psi with no water in the tank and see if your problems clear up. If not describe what is happening then.
    Gary
    Quality Water Associates
  4. kp
    kp New Member
    Jun 26, 2005
    Thanks for the answer. I'll try it out and let you know if that doesn't fix the problem.
  5. Pumpman
    Pumpman Pump Sales
    Apr 12, 2005
    Owner - R.L. Peeks Pump Sales
    So. Cal
    If there's a wire from the pressure sensor to a box with relays, it almost sounds like this is a constant pressure unit.
    Ron
  6. Gary Slusser
    Retired
    Good call Ron. I have no experience with constant pressure pump systems.
    Gary
  7. Pumpman
    Pumpman Pump Sales
    Apr 12, 2005
    So. Cal
    kp,
    Have someone check out your unit for you. It sounds like you may have a constant pressure (cp) unit, which has a very small differential, usually only a couple of psi. A cp unit will ramp the pump motor speed up and down to maintain the preset pressure. If the unit is working correctly, and the pump still cycles with no water demand, you may have a bad pressure tank. Pressure tanks on a cp unit are usually much smaller than what would normally be used.
    Ron
Similar Threads: Pump cycling
Pumps and Tanks Well Forum & Blog. Water is life. Pump is short cycling, not sure wha to do Jan 12, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Grundfos MQ3-35 booster pump short cycling Nov 30, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Pump is short-cycling. Tank bladder issue? Aug 30, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Well Pump Short Cycling Issue Jul 6, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Short cycling of well pump when no water is running Aug 2, 2015
