Pump cycling vs continuous operation
Discussion in 'Irrigation / Sprinkler Forum' started by OLDMAN, Jul 28, 2011.
  1. OLDMAN
    OLDMAN New Member
    Jul 27, 2011
    Retired engineer from a defense contractor
    Michigan
    I have a well and pressure tank. During the operation of my irrigation system, on the first two zones the pump runs continuously at 44 PSI. On the other three zones, the pump cycles on and off (30-50 PSI). Please advise me which is the preferable condition.
    You have a fabulous site! Found it on Google.
  2. zl700
    zl700 DIY Senior Member
    Aug 26, 2009
    Western NY
    Constant operation is preferred
    Motor cycling is tough on the equipment
    Amperage draw is always higher on starting versus running so pump cycling could use more energy depending on cycle rates.
  4. OLDMAN
    OLDMAN New Member
    Jul 27, 2011
    Michigan
    Thanx 700, I shall replace the nozzles in the 3 zones which are cycling, with larger orifice nozzles; that should increase my volume and, hopefully, result in continuous operation of my pump.
  5. OLDMAN
    OLDMAN New Member
    Jul 27, 2011
    Michigan
    I replaced the nozzles in the 3 "problem" zones and, voila, I am now getting the desired continuous pump running full time in all zones. Again, thanx "zl700."
Similar Threads: Pump cycling
Irrigation / Sprinkler Forum Pump cycling vs continuous operation Jul 28, 2011
Irrigation / Sprinkler Forum Irrigation pump short cycling overheating...GGRGGR Jun 14, 2008
Irrigation / Sprinkler Forum How to calculate pressure to choose water pump Dec 26, 2016
Irrigation / Sprinkler Forum Shallow well pump issues Sep 24, 2016
Irrigation / Sprinkler Forum Simple garden hose sprinkler on Well pump issue Jun 25, 2016
