done_right
- Messages
- 1
- Reaction score
- 0
- Points
- 0
I searched this forum, but couldn't find an answer to my problem. I have an old Goulds shallow jet well pump that has worked without a problem for 25 years. The pump motor last night smelled of burnt electrical and was rather hot. I turned it off and let it cool. It now turns on at 21 psi like it should, but turns off before reaching the cutout and the motor gets hot. It would turn off at about 30 psi then after a few minutes turn on and go up a few psi and then turn off and do the same thing until it finally reached the cutoff (45 psi).
The pump is for a sand point well and I have a well-x-trol pressure tank. The line pressure does not drop at all it just cycles before reaching cutout. I will most likely replace the pump since it is so old, unless it is an easy fix. Any good pumps for a sand point well???
