cvg
Three wired submersible pump.
Pump will cut on and then will stop after after a min or so, stay off for a min and start again. Sometimes 3 or 4 times until the pressure has reached the shut off limit.
Note that the contacts on the pressure switch are closed the whole time until shut off pressure is reached
Pump does not do this all the time but is getting worse. I have replace two start capacitors and a relay in the control box. I have a new pressure switch so that not the problem.
Could the pump be going bad or can the control box, witch is in a closed box outside be the problem
