Pump cannot build adequate pressure
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by EricL, Nov 22, 2009.
  1. EricL
    EricL New Member
    Nov 22, 2009
    Accountant
    Tallahassee, Fl.
    I have a 1HP submersible at 40 feet in a 80 foot well. The well is 6-7 years old. I just had the two 20' galvanized pipes in the well replaced last year as a result of a leak, when the pump stayed on with low pressure. This leads me to believe it is a different problem than last years leaking galvanized well pipe, but it I suppose they could have gone bad again after only a year.
    The pump stays on and will not go above 20#'s of pressure. I have a 120 gallon holding tank that my pressure switch and gauge are attached to. It didn't appear to be waterlogged, but just in case I drained that tank and took out the plug in the top of the tank to make sure air got back in it. I screwed the plug back in the tank and turned the pump back on, but again pressure only hit 20#s. My normal setting is 50# min and 70# max.
    Do you have any suggestions on how to isolate the problem? Mainly I wanted to make sure it wasn't something simple before calling the well guy which has been running me about $500 almost once a year. Between corroded wires, lightning strikes, and leaking pipes I have had to have my pump pulled out the ground 4 times in the past six years.
    If I need a new pump I would like to increase capacity from 1HP to maybe 1.5HP. Is that advisable, and what is the best submersible pump?
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    Sounds like you have another hole in the drop pipe. I would change the galve pipe to sch 80 PVC or poly pipe.
  4. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    You could check that the pump is pulling 1840w.
Similar Threads: Pump cannot
Pumps and Tanks Well Forum & Blog. Water is life. Real world vs rule of thumb - How do you figure GPM & what happens if pump cannot meet demand? Oct 29, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Cannot remove impeller on Diamond 1HP jet pump May 16, 2013
Pumps and Tanks Well Forum & Blog. Water is life. Helplease....Sprinkler pump and pressure tank Saturday at 7:51 PM
Pumps and Tanks Well Forum & Blog. Water is life. Well pump varies, Please help I'm clueless Wednesday at 9:38 PM
Pumps and Tanks Well Forum & Blog. Water is life. Shallow well jet pump failing to reach cutoff Wednesday at 7:59 AM
