pulling wires in a wall
Discussion in 'Electrical Forum discussion & Blog' started by Taylor, Dec 27, 2010.
  1. Taylor
    Taylor New Member
    Mar 9, 2005
    Northern Joisey
    I believe the rule is max 2 wires per hole when pulling through a stud wall. Can I mix 12g and 8g wires in the holes? The holes for the latter are big, more than 2", and I'd rather just pull an extra wire through those than drilling yet more holes in this wall that carries all the conductors from the main panel.
    Thanks.
  2. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    There is NO "max 2 wires per hole" rule. There are derating rules, and many will argue that pulling through holes in studs does not apply, but IMO that does not matter if you keep to no more than four cables to a hole with up to #10 conductors. There are code reasons for this which I won't go into right now.
    I must ask, where are you drilling 2" holes in framing? 2x6 walls? I hope they are dead center.
  4. Taylor
    Taylor New Member
    Mar 9, 2005
    Northern Joisey
    Thanks.
    The holes are in 2x6 walls, it's in a basement so the only load is drywall, maintaining 1-1/4" distance from the edge etc.
Similar Threads: pulling wires
Electrical Forum discussion & Blog Pulling low voltage wires through metal studs Aug 31, 2009
Electrical Forum discussion & Blog pulling 8-3 romex Feb 10, 2011
Electrical Forum discussion & Blog Installing Ceiling Fan Box and Pulling Romex Jun 23, 2010
Electrical Forum discussion & Blog Pulling wire through existing conduit Nov 20, 2008
Electrical Forum discussion & Blog Dual oven with 6 wires Nov 10, 2016
