Pulling my sand point
Discussion in 'Pumps and Tanks Well Forum & Blog' started by Wet Willy, May 15, 2007.
  1. Wet Willy
    Wet Willy New Member
    May 15, 2007
    How dose a guy get these things out of the ground? I am building a cabin and wanted a sand point for a well the water table is around 25' to 35' according to wells that are drilled in the area the wells are drilled from 40' to 60' but till I found this out I pounded in a 1 1/4" pipe to 35 feet and I have about 2' or so of water in the pipe. Now I know I have to go to a 2" pipe so I can reach a good amount of water I figure I will go to 60' at best guess at this time but would like to get the other out, I have got it to move about a foot out and that's it I have a 2000 lbs winch and a 2ton floor jack and a 1.5 ton bottle jack on it and it will not move any more. Please help. Thanks
  2. toolaholic
    toolaholic General Contractor Carpenter
    Jul 16, 2005
    Repairing and remodeling homes
    Marin Co. Ca.
    Here You go Bud
    I use to live an build on Cape Cod. I put in 7 wells with sand points. To pull them get 2 -4x4"s or 4x6 s about
    12 ft long .drill and install a 3/4" carriage bolt on one end . lock 2 pipe wrenches facing each other around pipe
    With a large block as a fulcrum pusn down on the end of the lever. keep repeating this untill it's out
  4. HandyAndy
    HandyAndy General Contractor, Farmer
    Apr 17, 2007
    Haxtun, CO
    There are times when a good tractor loader can not pull a fence post 2 to 3 feet in the ground out, jsut yesterday I had a 1/2 smooth rod electric fence post that I had to use the tractor loader on jsut 12" deep.
    Unless the pipe is loose, (like the above post can be turned or moved) my guess is you will have to dig down cut off the pipe seal it up properly for an abandon well and forget it,
    do a Google search for "plugging abandon well" and your "state" to find the proper ways of doing it,
    usually it is a form of filling it and sealing it so no transfer of liquids can reach the ground water, and some form of a cement cap.
    and if you do have to abandon it, DO SEAL IT UP PROPERLY for your own protection, it is your water your drinking.
  5. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    Points can be slide-hammered out, but the equipment may be hard to find.
  6. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    I think your spinning your wheels. You only have 2 feet of water at thirty some feet and your planning on going to 60 feet by hand. I don't see the likliehood of that. I honestly think your going to need a driller to do this for you.
    bob...
  7. Wet Willy
    May 15, 2007
    I hear that speedbump .I would like to get this one out for I would have a good start at the 2" I hear you can drive these things in with a jack hammer anyone ever try that.
  8. speedbump
    Jul 15, 2005
    Riverview, Fl.
    I don't think the threads or couplings can take the pounding a jack hammer can produce.
    bob...
Similar Threads: Pulling sand
Pumps and Tanks Well Forum & Blog well pulling sand Jul 13, 2016
Pumps and Tanks Well Forum & Blog Can I use a CSV on this without pulling the pump? Aug 17, 2016
Pumps and Tanks Well Forum & Blog Advise for pulling a pump in Honduras Nov 28, 2015
Pumps and Tanks Well Forum & Blog Help pulling well pump Jun 20, 2013
Pumps and Tanks Well Forum & Blog Pulling 100 ft. deep 2 inch packer well May 7, 2013
