Pulling a submersible - not sure if this is right
Discussion in 'Pumps and Tanks Well Forum & Blog' started by bigdaddy, May 19, 2012.
  1. bigdaddy
    bigdaddy New Member
    May 19, 2012
    Michigan
    OK I'm a little green at this so please forgive any ignorance on my part. I've gone through all the checks for low pressure issues and now believe that I need to pull the submersible for some checks. I'm using a 1/2 ton electric hoist to pull up but it's not moving. How much lifting power is needed? am I doing something wrong? do all submersibles have the same pitless adapter which requires a straight pull up or is possible the pipe needs to be turned/unscrewed?
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    I know of at least three different styles of pitless and only one pulls up without any special release mechanism. One style needs to be unscrewed and the other style has a crow's foot with release cable.
  4. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
  5. bigdaddy
    bigdaddy New Member
    May 19, 2012
    Michigan
    Yes looks just like part A - above. I'm still a little unsure how to release it.
  6. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    You need a special tool that goes down through the support pipe and unscrews item F or M.
  7. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
  8. bigdaddy
    bigdaddy New Member
    May 19, 2012
    Michigan
    OK, I see now. Thanks. Now hopefully I didn't already damage it by lifting the whole assembly up about one inch.
  9. bigdaddy
    bigdaddy New Member
    May 19, 2012
    Michigan
    Thanks for the help. local hardware or big box stores didn't have the tool and it didn't want to wait for one to be shipped so I ended up using a 1/2 inch pipe and notched out the center like above and worked fine. Thankfully I didn't do any damage all is working good now.
Similar Threads: Pulling submersible
Pumps and Tanks Well Forum & Blog Pulling a submersible pump-Bad news!!! May 18, 2006
Pumps and Tanks Well Forum & Blog Pulling a submersible pump Apr 22, 2006
Pumps and Tanks Well Forum & Blog Can I use a CSV on this without pulling the pump? Aug 17, 2016
Pumps and Tanks Well Forum & Blog well pulling sand Jul 13, 2016
Pumps and Tanks Well Forum & Blog Advise for pulling a pump in Honduras Nov 28, 2015
