Pulling 100 ft. deep 2 inch packer well
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by homesteader, May 7, 2013.
  1. homesteader
    homesteader New Member
    May 7, 2013
    louisiana
    I have a 100 ft. deep 2 inch packer well with a 1 inch drop pipe. casing and drop pipe are
    galvinized. the well was dug in 1962, has not been used for about 40 yrs. I attempted to
    pull the drop pipe, will not budge or turn. pored 1 gallon of chlorex between drop pipe and 2 inch
    casing, still stuck. Any suggestions would be greatly appreciated.
    thanks
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    Packers are not easy to pull. You will probably need a good hoist.
  4. homesteader
    May 7, 2013
    louisiana
    valveman:
    thank you for your suggestion.
    I attached a cross member at the top of the drop pipe and put a hydrylic jack under
    each end. I'am afraid if I apply more pressure it may break?
    is there anything I can pore down the 2 inch casing to loosen the leathers?
    thanks
    homesteader
  5. craigpump
    craigpump Well-Known Member
    Apr 12, 2012
    Self employed water system tech
    After 50 years you need a good hoist truck and hope the pipe doesn't pull apart
  6. valveman
    Mar 15, 2006
    Lubbock, Texas
    Yeah this is what I meant also.
Similar Threads: Pulling deep
Pumps and Tanks Well Forum & Blog. Water is life. Pulling a deep well pump Nov 2, 2009
Pumps and Tanks Well Forum & Blog. Water is life. Silt in deep well after pulling the pump Feb 15, 2009
Pumps and Tanks Well Forum & Blog. Water is life. Can I use a CSV on this without pulling the pump? Aug 17, 2016
Pumps and Tanks Well Forum & Blog. Water is life. well pulling sand Jul 13, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Advise for pulling a pump in Honduras Nov 28, 2015
