PRV placement relative to ball-valve
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by DavidTu, Apr 16, 2012.
  1. DavidTu
    DavidTu Member
    Dec 3, 2009
    Seattle, WA
    Does it matter if pressure reducing valve is placed before or after the building supply main on/off ball valve?
  2. hj
    No, but it is easier to service and replace if it is after the valve.
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Seems to me the ball valve should shut everything off, so I put my valve where the supply line enters the house which is about 4 feet above the basement floor. The PRV is a couple of feet above that. This is one reason why I can't understand why someone would put their PRV at the meter.
  5. Winslow
    Winslow Plumber
    Dec 30, 2005
    Hawaii
    the valve should always be placed first.
  6. hj
    When the PRV is at the meter it is to keep the high pressure out of the pipe to the house. SInce there is a valve at the meter, the PRV can be anywhere after the meter, regaridless of where the house valve is.
  7. Gary Swart
    Sep 1, 2004
    Yakima WA
    HJ is of course correct, but if the supply line to the house is in such poor condition it can not withstand the high pressure, you will have a supply line problem in you very near future.
  8. hj
    It does not have to be "poor", the main pressure could be so high, (which is why the PRV is needed), that it exceeds the recommendation for the plastic line used. Or someone may not trust the plastic to not fail at city pressure.
  9. jadnashua
    While maybe not common, there are places where you need TWO PRVs, plumbed in series to drop the pressure to an acceptable level. So, if it was REALLY high, the utility might get it down to very high, then let you deal with it to drop it further, if needed. There's a limit on how much a prv can drop the pressure.
Similar Threads: placement relative
Plumbing Forum, Professional & DIY Advice Cast iron tub ledger board placement Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Moen Chateau knob replacement ? Feb 9, 2017
Plumbing Forum, Professional & DIY Advice P Trap replacement Feb 5, 2017
Plumbing Forum, Professional & DIY Advice Tub-Shower Valve Stem ID/Removal/Replacement Jan 31, 2017
Plumbing Forum, Professional & DIY Advice Replacement Handle for American Standard Tub/Shower Jan 17, 2017
