Hello all.
I’m in the midst of reworking some of my old plumbing, and among the work is replacing a broken PRV. I have installed a new Watts LFX65B (chosen due to space constraints as well as its cartridge-style serviceability…) and have set the static pressure to 60 PSI. My incoming street pressure is 125 PSI.
Now, when I go to turn on a fairly high-flowing outlet, such as my outside hose bib, the new PRV starts to flutter or chatter, causing unstable pressure conditions, pre and post PRV. On the regulated side, the pressure gauge indicates fluttering back and forth +/- 20 psi from ~ 50 psi (which is 10 psi less than the static set point of 60). However on the high side (street side), the pressure gauge gets slammed and is so out of whack that it goes around and around the dial, clicking at each turn! (That gauge is for sure now damaged or mis-calibrated from all the hammering that it no longer indicates the correct incoming 125 PSI when all is static. I have another gauge to confirm street pressure remains at 125 psi.)
Please see this video of the chattering in action:
This does not happing 100% of the time, but I can’t seem to figure out what specifically causes this or what specifically prevents this.
For example, when I slowing open a bath sink faucet, the chatter does not usually happen. However if I do open the same faucet the same way after a chattering incident, then it will most likely resume the chatter mayhem.
The chatter seems to happen most often when I open a high-flowing faucet quickly. I have also caused it to go from no chatter to chatter by opening multiple sink faucets on at a time and then a bath tub spout - resulting in system high flow. However the chatter seems to NOT happen most often (but not 100%) when I open any faucet very slowly or partially.
It seems the PRV needs a “rest” after a chattering incident before I can attempt to slowly open a faucet in order to keep it stable. Opening and closing faucets quickly and rapidly seems to stimulate it to chatter.
The PRV is installed in the correct flow direction.
It is plumbed 1” in and 1” out (no reduction on either end).
I have removed the cartridge to make sure the screen is clean.
All upstream shut-off (full-port ball) valves are fully opened.
Any ideas why this is happening?
Is this PRV malfunctioning or just defective?
Should I get a replacement of the same?
Or should I get a different model / brand / or size?
Thanks in advance.
Thanks in advance.
