Protecting MC wires in PT framing
Discussion in 'Electrical Forum discussion & Blog' started by Taylor, Apr 16, 2008.
  1. Taylor
    Taylor New Member
    Mar 9, 2005
    Northern Joisey
    Thinking of framing my basement in PT lumber (I've seen what decades of basement moisture does to framing). I'll be running MC cabling because I'll have foam insulation up against the outside walls. My question is, are there grommets of some kind (presumably of plastic) that I can use to protect the wires when they go through the PT lumber?
    I guess an alternative is running PVC conduit but (a) it's a lot of conduit and (b) on the wall where the circuit panel sits, there would be a lot of conduit.
  2. Taylor
    Taylor New Member
    Mar 9, 2005
    Northern Joisey
    On second thoughts....
    From the EPA..... Maybe I'll stick to PT for the plates.....
  4. RRW
    RRW New Member
    Jul 15, 2005
    Illinois
    I don't think pressure treated lumber has formaldehyde in it. HCOH is found in plywood, carpet, probably laminatedbeams, etc. PT has stuff a lot worse for you than formaldehyde, but not very air mobil.
  5. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    Good call!
  6. hj
    Pt
    If you need PT studs for the walls, then you have a bigger issue than what kind of wires to install.
Similar Threads: Protecting wires
Electrical Forum discussion & Blog Dual oven with 6 wires Nov 10, 2016
Electrical Forum discussion & Blog Controller or switch for thermostat wires Aug 22, 2016
Electrical Forum discussion & Blog How many #6 wires in 3/4 inch rigid conduit? Jun 8, 2016
Electrical Forum discussion & Blog STAPLING WIRES Feb 19, 2015
Electrical Forum discussion & Blog Lowering Ceiling: How to Extend Ceiling Light Wires Jan 1, 2015
