Protecting copper from cast iron
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by sethamin, Mar 18, 2013.
  1. sethamin
    sethamin New Member
    Feb 21, 2013
    Brooklyn, NY, United States
    My plumber ran some supply lines in a very narrow brick channel next to the cast iron waste stack. Unfortunately, the copper and cast iron are touching at points, and the channel is so narrow that it's not possible to get any foam insulation in there. What else can I use to protect the copper from corrosion? I obviously want something that will last a long time. I was thinking of putting some vinyl PVC wrap tape between the CI and the Copper. Will that work? Other suggestions?
  2. Terry
    Aug 17, 2004
    They in fact do make a plastic wrap for copper pipe. The stuff I use says UPC tape. I don't know what they sell in IPC country. But yes, you can throw some tape on the pipe.
  4. sethamin
    sethamin New Member
    Feb 21, 2013
    Good to know. I can't seem to find the stuff online anywhere, though. This is the closest I've come across:
    http://www.northtowncompany.com/polyc.html
    Any other keywords you can suggest? I am under UPC, so maybe I can just call my local plumbing supply store and they'll have what you describe.
  5. Hairyhosebib
    Hairyhosebib New Member
    Jun 23, 2010
    Arizona
    You could go to a craft or hobby shop and buy some sheet styrene. Cut some strips, slob some glue on and shove it in. It should never move, rot or rust. You could also go the the meet counter and buy a steak and use that thin styrofoam thing that they come packaged in. While your steak is cooking on the grill, wash it, cut it , glue it , and stick it between the pipes then go eat your steak.
  6. hj
    There is going to be very little, if any, movement so it makes little difference what you use to separate the pipes. Duct tape, cardboard, or any kind of plastic tape is sufficient.
Similar Threads: Protecting copper
Plumbing Forum, Professional & DIY Advice Protecting pipe from freeze in cold attic Feb 4, 2015
Plumbing Forum, Professional & DIY Advice Protecting PEX from UV Apr 1, 2010
Plumbing Forum, Professional & DIY Advice Protecting cabinets from leaking valves Jul 15, 2008
Plumbing Forum, Professional & DIY Advice 3 Inch copper waste pipe cracked and leaking. Monday at 10:12 AM
Plumbing Forum, Professional & DIY Advice Replacing Copper Water Supply Line with PEX? Feb 2, 2017
