Yi Ma
"Well Pressure Tanks store water from your well and reduce wear on your pump by avoiding the necessity of your pump switching on and off constantly as people in your house use sinks, showers etc. Also well pressure tanks help to keep the water pressure constant in between operations of your pump. If you don’t have a good well pressure tank and you are having a shower, you may well feel the temperature of the water suddenly increase and burn you if someone flushes the toilet! This is due to the water pressure of the cold water supply dropping when someone else uses cold water."
Well I will offer a couple of corrections. First a pressure tank does not "avoid the necessity of your pump switching on and off constantly as people in the house use water". Switching on and off constantly is what a pressure tank CAUSES the pump to do. The larger the pressure tank, the less if cycles on and off, but it still continues to cycle constantly while water is being used. So well pressure tanks do not keep the pressure constant. The pressure is constantly changing from 40 to 60 while you are using water. Then even if you have a good pressure tank, you will still feel the temperature in the shower suddenly increase and decrease as the pressure constantly changes from 40 to 60 and 60 to 40 over and over.
A Cycle Stop Valve set at 50 PSI would keep the pressure at a constant 50 while water is being used. This keeps the pressure steady at 50 for as long as you are in the shower or using water anywhere, which eliminates the sudden changes in pressure and temperature when someone flushes a toilet or uses water elsewhere. But then you would only need a 4.5 gallon size pressure tank, as the CSV makes the water go right past the pressure tank directly to the shower or faucets, which makes a large tank completely unnecessary.
"The larger your tank, the better, in terms of minimizing on-off cycling of your pump."
If using a larger tank is better in terms of minimizing on/off cycles, and it is, then using a CSV to completely eliminate on/off cycling is even better.
"A larger tank also will cut your electricity bill, as there is a current surge each time the pump is turned on and reaches operating speed."
It only takes a regular pump a fraction of a second to get to operating speed. So you could start a pump 300 times per day and you would not be able to see a difference in the electric bill from a pump that started 20 times a day using a larger tank. But there is a slight increase in energy consumption for pumps that cycle on and off a lot. That being said, a CSV will completely eliminate cycling when water is being used for long periods of time. So using a CSV and small tank to keep the pump running constantly would use less starting energy than a system with any size pressure tank that continues to cycle on and off.
I still use 86 gallon WX302 pressure tanks, but only to run large pump systems like in post #7 where with a CSV it supplies water to a city with 20,000 people. Big pressure tanks for use in single houses have become obsolete, as there are now much better ways to eliminate, not just reduce the pump cycling.
Hi Valveman,
Thank you very much for replying in such detail! I will adjust the article accordingly.
