Pros/cons of depowering well when not used.
mnclimber
Minneapolis, Minnesota
I have a well at my house that is strictly used for irrigation, so it's not used during the winter. Although I'm in MN, everything well-related is either in the house or below the frost line, so I'm not worried about freezing. I've always left the well powered through the winter, but I'm wondering what the pros/cons of turning the power off during the winter would be and if there is anything special I need to do for shutdown or startup.
Thanks for any insight you can provide.
Turning off the power would make no difference unless there was a failure of some sort. I would turn it off, but I would turn it back on early enough that a failure of a pipe or pressure tank would be detected with enough time to make the repair not very urgent.
I am not a pro.
mnclimber
Thanks for the reply. Any thoughts on whether it's better to drain the pressure tank or leave it pressurized? Anything else I should be considering on shutdown?
ACWxRADR
Omaha, Nebraska
mnclimber,
If you absolutely have no fears about freezing then...
If your pressure tank has a bladder, I would recommend releasing just enough water from the system so that the bladder can relax. You wouldn't desire to drain it completely, but just to a point slightly above the kick on pressure. At this pressure, the bladder would not be expanded nor compressed. The pressure on each side of the bladder would be nearly equal.
If you fear freezing, then I would do the same, but feed the intake of the pump (if not a submersible) with RV antifreeze and allow it to be distributed throughout the entire system. If you have a submersible, then I would disconnect the line coming from the submersible and force RV antifreeze into the above ground plumbing with a portable pump.
RADAR
