Pros and Cons of Using AAVs
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by dondiy, Oct 17, 2007.
  1. dondiy
    dondiy New Member
    Oct 10, 2007
    Hi All:
    After reading many of these threads about venting, it sounds like there is never a bad time to use an AAV to vent a fixture. It also seems more cost effective to use AAVs instead of having to route pipe all the way to the roof?
    When or why would you not want to use a AAV to vent a fixture?
  2. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    AAVs....are great
    You will hear a howl of protests here in a while...
    their are some here that would rather use a chain saw
    and literally cut the house down to get a vent out
    the roof .......instead of a 5 dolllar AAv...
    I like them and use them sometimes..and they can be life
    savers in difficult situations..
    In my old home I installed them extensively in the basement remodel where I could not get a vent
    out of the house without doing the chain saw method...
    their is one behind the lavatory,...one behind the
    laundry, and one behind the toilet....
    they are all still working to this day...15 years later...
    depending on the codes......
    we all have our own crosses to bear...
    to each his own.....
  4. TMB9862
    TMB9862 New Member
    Nov 12, 2006
    Mark pretty much summed it up. First make sure they're legal in your area. If they are avoid using them if possible but if you don't have much of a choice go ahead and use one.
  5. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    However you install them, make sure you leave access to the valve on the chance you need to replace one of them.
  6. hj
    Aav
    AAV's have three advantages.
    1. They are cheap
    2. They are easy to install.
    3. The save installation costs
    Their main disadvantages are;
    1. If the underground drain line stops up anywhere the sink will not drain and you will not know if it is just the sink drain or the entire plumbing system that needs servicing.
    2. The will reduce negative pressures but not positive pressure which can also cause a sink not to drain.
    3. They are a handyman way to do plumbing unless the situation is so serious that they are the only solution. Ancient plumbing systems being about the only ones which qualify.
  7. hj
    Aav
    1. They are cheap
Similar Threads: Pros Cons
Plumbing Forum, Professional & DIY Advice Hot water heating zones, pros and cons Jun 22, 2014
Plumbing Forum, Professional & DIY Advice PEX Pros and Cons Nov 13, 2007
Plumbing Forum, Professional & DIY Advice Pros and cons....Uniforms for a more professionial looking plumber. Jun 30, 2007
Plumbing Forum, Professional & DIY Advice Compression, Sweat, and Threaded Fitttings: The Pros and Cons Jan 23, 2006
Plumbing Forum, Professional & DIY Advice water heater leaseing?? your opinions--pros and cons Nov 11, 2005
