Proprietary Faucet Supply Lines - Are They Good?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by mattbeme, Mar 17, 2009.
  1. mattbeme
    mattbeme New Member
    Mar 17, 2009
    Canada
    See Pic Below for an Example.
    I am talking about the proprietary flexible supply lines that many faucets come with now. The ones with a 'special' fitting , usually narrow, that plugs-in in some way to the faucet valve body. The other end of these hoses/lines connect to the supply shut-off valves as usual.
    1. Do these proprietary lines lock-in, screw-in to the valve body of the faucet?
    2. Do they use O rings?
    3. Do they provide long lasting and reliable water-tight service?
    4. Do the manufacturers provide replacements if needed? Naturally, you can't buy them anywhere other than the manufacturer.
    Matt B
    --Notice the 2 braided lines with the long, narrow fittings at one end. These fittings go into the bottom of the 'valve body' of the faucet. Notice there are no copper tubing stubs with threaded adapters sticking out from under the faucet valve body - like faucets used to be made.
    [​IMG]
  2. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    One too many threads on this whole issue...
    But post a pic of what you are referring to or a link.
Similar Threads: Proprietary Faucet
Plumbing Forum, Professional & DIY Advice Proprietary Faucet Supplies - Can I Solder in Copper Tubes? Mar 17, 2009
Plumbing Forum, Professional & DIY Advice RO Faucet Air Gap Failure Yesterday at 11:03 AM
Plumbing Forum, Professional & DIY Advice Bathroom sink faucets: ceramic cartridge vs. washerless cartridge;PVD nickel vs regular Saturday at 5:58 PM
Plumbing Forum, Professional & DIY Advice Kraus faucet leaking Saturday at 1:43 AM
Plumbing Forum, Professional & DIY Advice Please help identify this faucet brand TY Tuesday at 3:53 PM
