Here is what I have and looking for advice.
53' well dug, 40' of 8" steel casing followed by 13' of 6" bore hole in basalt and at 47gpm. Have 33' of static water.
Proposal is to install Grundfos 30SQE10-130 pump, with a Grundfos CU130 Continuos Pressure Pump controller and a Pentair Pro-Source 119gal pressure tank. The pump will be set at the 40' depth and using a 1 1/2" galvanized steel drop pipe. Plan on changing this to schedule 120 pvc drop pipe.
The well head is 12' from a 9x9 pump house using 6" SIP build. Pump house will have heat and light and center floor drain. All plumbing and conduit will be coming up thru the concrete floor. Conduit will be stubbed separately for future 3 bed room home and shop a maximum of 300' away from the pump house. Plus irrigation of a 2 acre yard. Also plan to install a minimum of two frost free hydrants, one close to the pump house and one 200' feet away. I want to have 30gpm volume to all locations. Any suggestions for this project are welcomed.
Idaho2
Idaho2
