ProPEX shower valve instalation
Cris2017
California
I have a cpl quick questions:
First what are the different options to install a shower valve while using ProPEX Uponor.
I can go to the supply lines and up to the shower head with 1/2 PEX line, but I cannot go to the tub spout with 1/2, so if I don't want to solder copper, is there any other option than running 3/4" line from valve to bath spout?
Second, any concerns about running 3/4 throughout the house and splitting to 1/2 at lav/toilet/shower?
Thank you so much for all input!
Asktom
Victor, MT
For the tub spit you could use a galvanized or brass nipple and elbow. I like brass.
I can go to the supply lines and up to the shower head with 1/2 pex line, but I cannot go to the tub spout with 1/2,
Why is that?
You can get ProPEX Drop Ear Elbows in 1/2 and 3/4. Then you can run a brass nipple from there.
Cris2017
California
I do have the ProPEX drop ear elbow, but my understanding is that you cannot use1/2 PEX line from valve to down tub spout, as the ID of the pex line is smaller than copper which will result in higher pressure and water trickling up to the shower head (path of least resistance).
So the question then is how do I connect from the valve to the down tub spout? Most recommendations I've seen were to either use copper and solder it (I would prefer not to do that), or use 3/4 pex. Any other options?
If you install that fitting with 1/2" PEX, it will force water up to the shower head.
There can't be "any" reduction in size from copper or threaded pipes.
CPVC and PEX cannot be used on a tub spout.
NOPE!
Edited just recently
How are you going from 1/2" to 3/4" and back to 1/2"
Most tubs outlets are 1/2".
However you do that, there can't be any restriction. If you use a 1/2" x 3/4" PEX adapter, it won't work. It has to be copper sized or pipe sized.
A one bath home can be plumbed with 3/4".
A two bath requires 1"
A four bath normally requires 1-1/4"
I don't do more than two fixtures on 1/2".
Cris2017
California
Got it for the down spout.
As for the pipe throughout the house, the old copper ones are ALL 1/2, everywhere in the house (3 baths + kitchen). So, I was thinking about running 3/4" now to each one of them and then convert to 1/2 at the lav/toilet/shower/kitchen.
It sounds like they could sell a big brother of the Uponor LF4235038 if they decided to make one. That one is a 1/2" ProPEX x 3/8" FIP Drop Ear Elbow.
