ProPex Question...
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by OldPete, Nov 6, 2006.
  1. OldPete
    OldPete DIY Senior Member
    Jan 4, 2006
    NJ
    Let's say you have a 1/2" ProPex Water Closet (Cold) Line protruding from the wall. Now, let's say you've got the 1/2" chrome sleeve that fits (slides) over the pex to make things look nice. Now you have the ProPex Ring connecting the 1/2" pex to the Angle Stop. The Ring is larger than then chrome sleeve, so you end up with about 1/2" of pex and the entire Ring showing... not very neat if you ask me, and also, how does that protect the ring and the 1/2" of pex from UV, etc.?
    Thanks,
    Pete
  2. Cass
    Cass Plumber
    Nov 12, 2005
    Sorrry I can't help here I run copper into walls and make the connections there.
  4. OldPete
    Jan 4, 2006
    NJ
    Sure, Cass... do the logical thing and make my life harder! :D
  5. jadnashua
    They make copper stubouts specifically for this...then you can use any "normal" valve as you want.
  6. hj
    stop
    They make slip on stops for that purpose, (they use a push/pull knob to open and close), although I do not consider them the best ones made.
  7. OldPete
    Jan 4, 2006
    NJ
    Thanks all, So with the Chrome Full Port Quarter-Turn Angle Stop, and the now exposed ProPex Ring and about 1/2" of 1/2" Pex Showing... what do you recommend?
    Thanks again,
    Pete
  8. jadnashua
    Brasscraft (and I'm sure others) make compression shutoff valves designed to attach directly to the cut end of pex (is Propex, just a brand name?). In fact, it is the same valve as designed for copper with the exception that they include a stainless steel insert to reinforce the tubing so when you crank down on the compression nut, the tubing just doesn't collapse, and it can make a good connection. They also sell the bushings in bulk, if you can't find one packaged with the valve you want.
Similar Threads: ProPex Question
Plumbing Forum, Professional & DIY Advice Wirsbo ProPex Expander Tool & Pex-A - Question Aug 6, 2016
Plumbing Forum, Professional & DIY Advice Question re ProPEX stop valves for vanity faucet Jul 21, 2011
Plumbing Forum, Professional & DIY Advice Uponor PEX with non-ProPEX fittings Nov 1, 2016
Plumbing Forum, Professional & DIY Advice Who Rents ProPex Expander Tools in the Seattle - Bellingham Area? Apr 7, 2016
Plumbing Forum, Professional & DIY Advice Hammer Arrestor to ProPex .. suggestions Nov 30, 2013
