theparkway
I am finishing my basement, where we had the builder put a drain line in for a kitchenette. I am wanting to also put in a second laundry in the basement, and have it share the same drain. The drain is 2 inch coming out of the slab. I have purchased the parts for the drain but want to make sure I am doing things correctly before drywall goes up.
There is no vent that goes up through the main level and to the outside, so as I understand it, the only real option is to use a AAV. My question is do I have to have an AAV both above the sink drain, and somewhere between the washer drain and the sink drain? I have attached a picture of what I have done, dry fitted together.
Also, I purchased a short bend 90 to make the turn to the washer, but after doing some reading, it seems that I should have purchased a sweep 90 instead, is this accurate, or can I stick with the short bend 90?
Thank you in advance for any help.
Tyler
Tyler
