Proper treatment of disconnected circuit
Rousifier
Alberta, Canada
We have a gas stove on 120v and, in the interests of preserving for a future owner, have left the 240v electrical range plug hooked up and functional behind the stove. Now, we're thinking we're going to be here a while and would like to make use of both legs of that hookup. How does one properly deal with the disconnected wires? Wire nut them and label and leave them in the box? Turn them, tape them, label them and leave them outside the box? Mix em up, solder 'em together and leave an internet surveillance camera in the room to view their reaction when the flash takes place? Want to do the best by future owners, but hesitant to waste the entertainment opportunity :). No, seriously...,
Tks
R.
Cacher_Chick
Test, Don't Guess!
If I am understanding correctly, you want to use the spaces in the main panel that the range circuit is currently connected to. This will require you to replace the breaker also.
I like to keep things neat and clean, so I would remove the wires from the main panel and put them in a labeled junction box outside and adjacent to the panel so the connection could be easily restored later if need be.
A new range connection requires 4 conductors for a grounded receptacle, so if the current cable is 3-conductor NM, I would remove it entirely.
Kreemoweet
Seattle. WA
Well, Rousifier, you really need to explain more, because you wrote several contradictory statements, and its a guess as to what you meant.
It's always acceptable to leave capped wires in a proper, covered electrical box. Depending on what they are, the old oven wires may not
be suitable for any other use.
Jbfan74
Electrical Contractor
Newnan, GA
Remove the wires from the breaker, place wire nuts on them and push them out of the way.
Remove the breaker in question, and install the new circuits you want.
Leave the old breaker inside the panel.
JWelectric
Electrical Contractor/Instructor
North Carolina
By making the statement, “future owner” tells me that you are not planning on being there for too long. In that case I would not do anything to the circuit and leave it in tack. Who knows you might decide to change the range and need it yourself.
Either would be fine
If you decide to do this please post it on youtube so we all can see, ha, ha, ha.
