Proper termination of unused circuit
Discussion in 'Electrical Forum discussion & Blog' started by garyl53, Jun 14, 2007.
  1. garyl53
    garyl53 Engineer
    Dec 7, 2006
    Engineer
    Colorado
    Hi,
    I am removing a whole house fan since we have air conditioning and never use the fan. The opening and louvres, although insulated, are letting too much heat and cold transfer and it looks ugly in our main hallway.
    What is the proper method to disable the current electrical feed to the fan and to the switch/speed control in the hallway. I am assuming the main feed goes to the fan first and then the speed control wiring comes from the main fan area down to the speed control although I haven't been up there yet.
    Any help is appreciated.
    Thanks,
    Gary
  2. barrybpdx
    barrybpdx New Member
    Sep 15, 2005
    portland, or
    trace the circuit backwards to the point at which it branches to the fan and switch.
    if the circuit doesn't continue on beyond the fan and switch, then undo the hot and neutral wires that branch to the fan and switch and leave them capped in the box.
    if there's more stuff past the fan and switch, then just take the switch out of the circuit (cap the hot switch feed in the switch outlet box).
    and always turn off the breaker before you start.
    note - i'm not an electrician.
  4. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    None the less it was good advice and the same that I am giving
  5. Cass
    Cass Plumber
    Nov 12, 2005
    If the box cover or box itself ends up with a hole where there was a wire that you removed the hole needs to be covered / plugged properly.
  6. garyl53
    garyl53 Engineer
    Dec 7, 2006
    Engineer
    Colorado
    Thanks all for the answers.
    Gary
  7. Jeff1
    Jeff1 New Member
    May 24, 2006
    So Cal
    Why remove it?
    I have both A/C and a whole house fan and they complement each other very well. It has saved some $$ going to SCE. If it aint broke...
Similar Threads: Proper termination
Electrical Forum discussion & Blog Proper grounding of 3-wire submersible pump in metal well casing Jan 23, 2017
Electrical Forum discussion & Blog Proper way to install flood lights Jun 10, 2014
Electrical Forum discussion & Blog Is this subpanel wired properly? Mar 22, 2013
Electrical Forum discussion & Blog Proper way to test circuit safety Oct 14, 2012
Electrical Forum discussion & Blog Proper treatment of disconnected circuit Jan 2, 2012
