Proper Sub-straits for this tile installation
Discussion in 'Remodel Forum & Blog' started by wallskev, Mar 6, 2011.
  1. wallskev
    wallskev New Member
    May 14, 2009
    Manufacturing Consultant
    North Carolina,USA
    We are located in North Carolina, USA.
    We are converting a Exterior 14 x 18 screen porch into an all weather room and want to Tile the Floor.
    The space as a finished ceiling and will have all aluminum windows and glass enclosures and doors.
    The present floor is 1x6 decking with a small space between boards.
    2x8 Joists exist on 16†centers with cross beams every 4 feet
    There is an open crawl space below the floor that is enclosed with lattice.
    What should the proper method be to install tiles on top of the existing floor ?
    • What type of sheet material to place over the Boards ?
      [*]Plywood or Hardiboard
      [*] Hight to Bottom of House Door sill is 1/2 inch. ​
      [*]Which type of Ditra to use ?
      [*]What type of thinset or adhesives to use?
    We have not yet decided on the tile type. Do you have any recommendations ?
    Thank you in advance for your help.
  2. jadnashua
    When you say crossbeams, is this blocking or actual beams? IOW, what is the maximum length of any unsupported joist? You need the deflection ratings to be L/360 or better, and without the length, there's no way to tell.
    You can't tile directly to planks, you need a layer of at least 1/2" exterior glue rated ply (with C or better sides; i.e., no 'D' side). Then, you can use either a decoupling membrane or cbu. What are the dimmensions of the room? With lots of windows, you may need to make special provisions for expansion (about every 8' or so in full sun). Ditra is easier to install than cbu, and after you add up the screws and tape, not that bad in price difference as well. And, it works better, lots lighter to carry home, and cleaner and neater to cut. Ditra XL was designed for really troubled installs, it can work on 24" spacing of joists for example, and the extra height makes it easier to match up heights with typical tile to wood surfaces. The original Ditra would work fine here, since you aren't trying to match surface heights and don't need the extra protection it provides.
    No adhesives needed in that sandwich. First, make sure the planks are well screwed down to the joists. Screw the ply down to the planks, avoiding the joists (ideally, have the end 1/4-span or about 4" past the joist for your 16" OC spacing). Then, read the installation instruction manual on Ditra about the proper thinsets to use. Typically, it's a modified thinset to anchor it to the plywood, and an unmodified one on top to set the tile. Keep a gap around the edges - don't butt the tile up tight against a wall. When you grout it, don't grout that gap, either. This allows a little expansion, otherwise, you may have a tenting failure where you literally sheer off some tile as it tries to tent to accommodate for the expansion. If it is wide enough, you need intermediate expansion joints too, the spacing of those depends on how much sun it gets. Ditraset is an unmodified thinset spec'ed by Schluter that works quite well (made by Bostic if I remember correctly). Don't use the least expensive unmodified, as they often barely meet the spec, you want a little more leaway.
  4. wallskev
    wallskev New Member
    May 14, 2009
    North Carolina,USA
    There is a 4x4 bean at 6', supporting center of all the joists.
    Max Unsupported Joist is 6"
    Is it possible to use 3/8 plywood so I can keep the height to match the exterior door threshold finished height ?
  5. jadnashua
    No, the minimum that is strong enough to isolate the planks from the tile is 1/2". The planks just move too much with seasonal moisture changes and 3/8" is too weak. Now, if you tore the planks off, and replaced it with 3/4" T&G ply, your height issue goes away.
Similar Threads: Proper Sub-straits
Remodel Forum & Blog How can I (properly) build a simple rectangular deck? Jul 29, 2014
Remodel Forum & Blog Do I have the proper thinsets? Jul 23, 2013
Remodel Forum & Blog Contractor Flashed Windows improperly: How bad is this? Feb 21, 2013
Remodel Forum & Blog I want to properly vent a remodeled basement bath Dec 26, 2012
Remodel Forum & Blog Proper moving of stove, fridge and DW to not damage vinyl floor? Apr 14, 2011
