Proper settings Enertrol
Discussion in 'Boiler Forum' started by GregoryR, Oct 22, 2011.
  1. GregoryR
    GregoryR New Member
    Jul 20, 2011
    Maine, USA
    Hello,
    Could any of you help me with setting this thing (outdoor reset) up properly? People on this site were a real good help last time I had questions, and I thank all of you for your time.
    [​IMG]
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    I would need to know which model you have or a photo
  4. GregoryR
    GregoryR New Member
    Jul 20, 2011
    Maine, USA
    [​IMG]
    Uploaded with ImageShack.us
    I had tried to upload one earlier, but I think it was too large. This should work.
  5. Tom Sawyer
    Nov 29, 2010
    Maine
    Set the slide switch to mod and turn the dial to 160 to start. You're up here in Maine with me so, when it gets damn cold out, if the house won't heat, turn the dial up 20 degrees until it will. You can also try going lower if the house is heating ok. The dial is what sets the temperature differential between outside temp and boiler supply temp, adjusted for degree days. I found that 160 to 180 seems to work pretty good around here.
  6. GregoryR
    GregoryR New Member
    Jul 20, 2011
    Maine, USA
    Done and done, thanks so much. Hopefully we'll see some savings now that this thing is actually doing its job.
Similar Threads: Proper settings
Boiler Forum Sizing new Boiler properly (methodology) - mid atlantic Maryland Mar 21, 2013
Boiler Forum peerless combi 160 gas boiler circulator not controlling properly Oct 10, 2012
Boiler Forum Properly venting a Wei-McLain CGi-4E boiler into a flue? Jan 28, 2010
Boiler Forum Aquastat settings Dec 24, 2013
Boiler Forum Oil burner with Enertrol HWDT-R-S Settings Mar 16, 2013
