Proper double sink waste plumbing, with Disposer?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Rock51, Apr 26, 2009.
  1. Rock51
    Rock51 New Member
    Apr 26, 2009
    Washington
    Greetings,
    Before I found this forum and read some of the good threads, I re-plumbed the waste lines under my double kitchen sink. The tubular drain fitting attached to my Insinkerator came loose one time and made a big mess. And I did not prefer the usual baffled T-fitting for the disposer drain line, since I believed it constricted the flow from the disposer and made it work harder than it had to. The photos show the Before and After of my project. I'm interested in your feedback. Thanks in advance.
    BEFORE
    AFTER
  2. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    Hope you don't mind that I used the first pic as an example of how to arrange their pipes in another thread... :)
  4. Marty53
    Marty53 New Member
    Apr 10, 2009
    New York
    I don't think thats the correct usage of a combo wye.. you should use a san T in that application.
  5. Terry
    Aug 17, 2004
    That will work in your case.
    Since it's the p-trap that needs venting, and not the continuous waste, that combo fitting is fine.
    If you can pull up the black rubber tubing from the diswasher so that it drains down into the disposer, that would be a good tweak.
  6. Rock51
    Rock51 New Member
    Apr 26, 2009
    Washington
    Why isn't ABS used more often under kitchen sink?
    Thanks, everyone, for your comments.
    I would like to raise the DW drain hose, as Terry suggests, but how to do that? Where would I attach a hanger, since there's only cast iron sink above the loop? I guess I could install a hanger toward the back of the sink instead and raise the DW drain line in general, which would tend to raise the loop. What should I use for a hanger?
    Also, the DW drain hose is somewhat compressed in the loop (oval cross section instead of circular), because of the relatively small radius loop. I was concerned about restricted flow and that the DW drain water might back up out of the air gap. But the DW seems to drain just fine. Anything to be done here? Should I switch to a different hose that can be bent in the tight loop but stay round in cross-section?
    What do you think about my ABS/tubular mix under the sinks instead of all-tubular? (I go this idea from McLendon's Hdw (Seattle area) years ago.)
    I found that the tubular stuff, with so many hand-tightened joints, tended to loosen up over time. The ABS takes more work to install but it's really solid. The biggest problem is that the only available ABS p-trap has a threaded joint on just the sewer side. So, if I ever have to get to the trap, I have to loosen 3 threaded joints and remove all the ABS as one unit. Awkward but do-able.
    Thanks.
  7. hj
    drain
    What you have will work, the only problem is that "locknut joint" on the "P" trap outlet has a tendency to crack and/or strip.
  8. Rock51
    Rock51 New Member
    Apr 26, 2009
    Washington
    How to hang DW hose? Is hose OK with tight bend?
    Thanks.
  9. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    I find that tubular properly installed will stay in place just fine...
Similar Threads: Proper double
Plumbing Forum, Professional & DIY Advice Proper setup for double sink plumbing Mar 27, 2014
Plumbing Forum, Professional & DIY Advice Proper plumbing for double sink w/ disposal Oct 25, 2007
Plumbing Forum, Professional & DIY Advice Is this a proper vent for a double vanity? Jan 13, 2005
Plumbing Forum, Professional & DIY Advice Proper drain slope on short run Feb 7, 2017
Plumbing Forum, Professional & DIY Advice Proper material for outdoor risers and manifold Feb 3, 2017
