Programming help for a Fleck 5600SXT 64K system
ColeMcDougal
Cincinnati, OH
In need of programming assistance for my 2 cu. ft. (64K) Fleck 5600SXT system:
- 4 people in the house: avg 150 gpd
- 21 gpg water hardness
Thanks in advance!
Water Softener Noobie
ditttohead
Water systems designer, R&D
Ontario California
DF set to Gal,
VT set to dF1b,
CT set to Fd
C set to 48.0
H set to 24
RS set to RC
rc SET TO 240
DO set 21
RT set to 2:00
B1 set to 7
BD set to 60
RR set to 5
BF set to 22 for .25 BLFC, 11 FOR .5 gpm blfc
17: FM set to 70.7 ASSUMING YOU HAVE A TURBINE METER. The turbine meter is a small meter sandwiched between the valve and bypass with a cable that plugs in. The paddle wheel (Less common) has a dome where the cable is secure in with a screw but... the screw will likely be replaced with a plug in meter cable as the stock of the old domes runs out.
There is also a NT setting, set to 1
