programing a fleck 5600 sxt 24K grain
Discussion in 'Water Softener Forum, Questions and Answers' started by love2byke, Apr 9, 2013.
  1. love2byke
    love2byke New Member
    Apr 9, 2013
    utah
    I've purchased and installed this softener but need help with the programing. I'm on city water rated at 8 for hardness, 2 people in the household and no other outside water demands. Can someone recommend the settings? Greatly appreciated.
  2. Gary Slusser
    Retired
    The people that you bought the unit from should tell you how to program the valve and what data to use.
    Who did you buy it from? What control valve do you have?
  4. Mikey
    Nov 8, 2005
    Consumer
    Hansville, Washington
    If you Google "Fleck 5600 Manual" you'll find several sources for information, including setup instructions.
  5. Gary Slusser
    Retired
    I see I missed what control he has... anyway, the manual will only show example data.
  6. love2byke
    Apr 9, 2013
    utah
    Control Settings
    Just to clarify, I have the manual and can see how to setup the controller. My question is more around what to set all the parameters to in order to optimize efficiency (timing of cycles, setting reserve, etc.)
    Here are the spec's I could find for my application:
    Fleck 5600SXT electronic metered
    24,000 grains capacity (0.75 cubic feet) 7" x 44" resin tank.
    Hardness: 158-170mg/L or 10 grains per gallon.
    TDS: 204 mg/L
    Resin: Standard 7% (Dow)
    Rated flow rate is 12 gpm at 15 psi drop.
    City water from 2 city wells.
    The official 'water report' from West Jordan Utah, where I live does not list the PH level, nor does it list iron/manganese content: http://www.sjc.utah.gov/pdf/waterqualityreport2011.pdf
    Thanks
  7. mialynette2003
    mialynette2003 Member
    Nov 24, 2010
    Owner of SWS Systems WWW.SWSSYSTEM.COM
    Ocala, Florida
    You might want to set it up like this:
    Capacity (C): 24.0 x 1000
    Water Hardness (H): 8
    Safety Factor (SF): 10%
    Day Override (DO): 14 days
    Backwash (BW) Default or around 8 min
    Brine Draw (BD) Default or around 50 min
    Rapid Rinse (RR) Default or around 10 min
    Brine Fill (BF) Depends on what BLFC you have but should be salted at 5 lbs
  8. Gary Slusser
    Retired
    Love2, a .75 cuft uses an 8"x 44" tank and has a constant SFR of 6.75 gpm. That fits very few houses or families.
    You can not get 24K with 5 lbs of salt, If you did, that would be a salt efficiency of 4800 grains per lb. That won't be happening.
    It takes 15 lbs to get 30K out of 1 cuft and that is an efficiency of 2000 grains/lb. It will take 12 lbs to get 24K out of 3/4 cuft with the same efficiency.
Similar Threads: programing fleck
Water Softener Forum, Questions and Answers Need help with Fleck 7000SXT programing May 25, 2014
Water Softener Forum, Questions and Answers Fleck 5600 Econo : Resin in Lines Yesterday at 8:25 PM
Water Softener Forum, Questions and Answers Fleck 5600sxt programming help Mar 21, 2017
Water Softener Forum, Questions and Answers Troubleshooting a Fleck 5600 Mar 17, 2017
Water Softener Forum, Questions and Answers What are the settings? Fleck 5600SXT city water Las Vegas Mar 11, 2017
