Problems with the Toto EL Drake CST744S
Discussion in 'Toilet Forum discussions' started by gb, Feb 17, 2010.
  1. gb
    gb New Member
    Jun 29, 2006
    About 3 years ago I came to this site looking for toilet recommendations.
    I ended up with the Toto RF Drake CST743S and the Toto EL Drake CST744S.
    I love the Toto's toilets. I have no problems with rounded front but the elongated one has given us some problems. Namely the flushing power. Sometimes it fine, but most times it seems like there's no force behind the flush. Often I will hear noise coming from the tank. I know I'm not being super clear about the problem - I was just wondering if the elongated fronts are more prone to be problematic. Thanks in advance.
    Also, do the rounded fronts and elongated fronts use the same tanks?
  2. Terry
    Aug 17, 2004
    There are four drake bowls and one tank for the 1.6 gallon.
    The only difference between the elongated and round bowl is the 1.5" at the end of the bowl.
    You can see the same thing by looking at the side.
    Same bowl, Same trapway, but one bowl extends just a little longer where it meets the end of the seat.
    Have you run a auger down the trapway to make sure the kids aren't dropping toys in the bowl?
  4. gb
    gb New Member
    Jun 29, 2006
    Thanks Terry. I'm pretty sure nothing is stuck in the trapway. I did notice that when I kept then handle down for a longer flush that's when I would run into problems. I took the tank lid off and notice that the fill valve was the one was making the noise. It looks like its running but the water wasn't filling up to the water line. The noise isn't loud - its more like a hissing sound. Do you think something about is wrong with fill valve? Or do you think its that flapper? Not a tight enough seal?
    Can I fix this myself? Do I need to order new parts from toto?
  5. Terry
    Aug 17, 2004
    If the tank is not filling, then there may be a bad flapper.
    So.........if you flush with less then a full tank, then yes.......that's not much of a flush.
    The staring point, is to have a tank that seals, and holds water for the next flush.
    www.terrylove.com/korky
Similar Threads: Problems Toto
Toilet Forum discussions Flush problems with Toto MS970CEMFG#01 Dec 12, 2016
Toilet Forum discussions Guinevere Toto toilet - too tight space creating problems - ideas to fix welcome! Pl Nov 16, 2013
Toilet Forum discussions Problems with Toto Ultramax MS851441SL Fill Valve Apr 4, 2013
Toilet Forum discussions Toto Nearest 500 flush problems Jan 3, 2012
Toilet Forum discussions Toto Dartmouth - Flapper Replacement Problems Nov 14, 2011
