Problems with my fleck valve, clicking noise
Discussion in 'Water Softener Forum, Questions and Answers' started by acrod, Jun 5, 2010.
  1. acrod
    acrod New Member
    Sep 24, 2009
    tx
    I have been having problems with fleck 8500 twin valve over the past few months, during the start of the cycle the gears start making this clicking noise and do not advance the cycle. I have been able to push the gear to get it going again and then it starts clicking and won't go anywhere. I took apart all the small plastic gears behind the control panel and there were no stripped teeth, everything looked as it should. I thought maybe it might have been the motor going out which I replaced but it is still doing the same thing. I have had it on bypass for the last 6 months as I can't seem to get it fixed, this water softener has been nothing but trouble for me since I bought it 3 years ago and I am ready to trash it!! Please help.
  2. Gary Slusser
    Retired
    It's probably a sticking piston and you need new seals, spacers a and piston, you have two of them in that valve; main and upper. Or it could be the brine piston sticking.
  4. acrod
    acrod New Member
    Sep 24, 2009
    tx
    I'm pretty mechanically inclined, is that difficult to do? Is this normal for a three year old softener, I know anything mechanical can break but you would think it wouldn't break down so early. How would I know which piston it is? Thanks.
  5. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    It is kind of a pain ... the 8500 can be rebuilt,, just did one and ...
    Is it the older style of the new SE or SXT?
  6. acrod
    acrod New Member
    Sep 24, 2009
    tx
    I'm not too sure, the manual says twinflo e. So it can be done without calling a professional? Is it worth it to rebuild it, or should I just buy a less expensive single tank meter, and be done with it? A two tank system is way more than my house needs anywas
  7. Akpsdvan
    Dec 29, 2009
    Alaska
    Does it have a digital control?
    It depends on where the clicking is coming from and what is making it click as to how costly it is going to be.
    A side note, the 8500 is coming to an end, Fleck or Pentair is no longer going to be making them if they have not already stopped making them.
    The 9100 is a much better and trouble free valve and would use the same meter turbin and bypass and brine tank and media tanks that you already have in place.
    While it might be more than your house of today might need, if you sell the place could a larger family move into your house?
  8. acrod
    acrod New Member
    Sep 24, 2009
    tx
    Digital control valve, the clicking seems to be coming from the downflow cam thing. Area. (Sorry, I'm not too versed in softener terms).
  9. Akpsdvan
    Dec 29, 2009
    Alaska
    Not a problem.
    There is a cam that moves the backwash piston in and out and also pushes the brine piston in for brine draw. There could be some thing not right and a noise is coming from it.
    There is the white cam on the front that controls the micro switchs for stopping the cam at each step of the cleaning cycle.
    There is a little like lock key on the big cam that controls the piston and brine piston, if that key gets taken out by the white cam locking then they will not turn in cynic ...
  10. acrod
    acrod New Member
    Sep 24, 2009
    tx
    Yes it seems to be coming from the white cam, but not 100% sure. Is there any way to Pinpoint the problem?
  11. Akpsdvan
    Dec 29, 2009
    Alaska
    You might be able to use a tube with one end by where you think the noise is coming from and the other end by your ear and see if that works.
    If it is coming from the white cam it could have started with the black cam that the white cam screws on to, or the gear that drives the black cam that is driven by the motor.
    It could be that the black cam's little locking ridge that locks the white cam in place has worn out and it is slipping.
  12. acrod
    acrod New Member
    Sep 24, 2009
    tx
    Thanks for all the help so far, so what would you say are my best options right now? Is it worth it to try and fix?
  13. Akpsdvan
    Dec 29, 2009
    Alaska
    Just did a rebuild.
    The main motor needed to be replaced, 125.0
    then the cage seal assembly 120.0
    black cam 20.00
    time spent working on changing of the parts, and the time spent on what was making it stop to before the backwash and before the brine draw...
    Your time has a $$$ to it, be it 25.00 or more...
    It could be a simple fix, then again it could run close to the 650 for a New 9100 SXT to take its place...
  14. acrod
    acrod New Member
    Sep 24, 2009
    tx
    very true about what my time is worth. It's just so frustrating when you have no idea what the problem is.
  15. Akpsdvan
    Dec 29, 2009
    Alaska
    Don't I know it, thought that the last one that I danced with would be straight forward and turned into FUBAR.
    Most of the time it is simple, but then there are times ....
    What you might look at doing is staying with a twin set up, but find a dealer that will give some kind of trade on what you have for a new 9100 with the SXT control, I put this on the table mainly because the Fleck 8500 old or new is on the way out, there will be a day soon that the parts will no longer be around.
Similar Threads: Problems fleck
Water Softener Forum, Questions and Answers Fleck 9100 SXT valve problems returned 60 days after replacing seals Feb 2, 2017
Water Softener Forum, Questions and Answers Problems with Fleck 7000 Mar 5, 2016
Water Softener Forum, Questions and Answers Fleck 9000 problems Jan 19, 2016
Water Softener Forum, Questions and Answers Problems with a 3200NXT timer on a Fleck 2900 Aug 17, 2015
Water Softener Forum, Questions and Answers Possible new problems on recently manufactured Fleck 7000 valves Feb 25, 2013
